While doing an overdue update onto my PDF-related "knowledge-base", I happened to find a tiny, self-contained application, which is able to simply wrap .JPG images in a PDF container
http://www.comicer.com/stronghorse/software/index.htm#FreePic2Pdf
N.B.: That page is written in Chinese, BUT it's not difficult to find the link to the English build of the binary.
HTH.Code:www.comicer.com/stronghorse/software/exe/FreePic2Pdf_eng.zip
Results 1 to 12 of 12
Thanks, El Heggunte!
I just tested it with a 10sec DV-AVI file, exported to JPG image sequence and converted to multipage PDF. Works perfectly!
Tried yours, too, fleminra, but had difficulty with the command line args for python, so skipped it for now...
Scott -
@ Scott: you're welcome =^.^=
@ fleminra: would it be too difficult to "translate" the Python code into something compilable with gcc -
Irfanview can do this as well. Batch mode can do a series of images. Works well.
--dES"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
IrfanView 4.30 cannot do the conversion WITHOUT recompression.
XnView probably cannot do the trick either.
And even though deflate compression is lossless, it's rather inefficient when compared to JPEG2000.Last edited by El Heggunte; 1st May 2013 at 21:18.
Thanks a lot El huggente,
thats a really nice trick ive actually been looking for something like this for a while^^
before i was using random online converters like this, but i dont feel that they are doing the job right.
so thanks alot
regards -
I assume that it wraps the files in a pdf wrapper with no change since the ouput file was the same size as the image files combined. I used bitmaps in my test.
Lossless Video Formats / Conversion
By mltwitz in forum Video ConversionReplies: 1Last Post: 13th Aug 2010, 14:57 -
Lossless conversion of imperfect TS (with sound dropouts) ?
By povlhp in forum Video ConversionReplies: 1Last Post: 9th Nov 2009, 16:24 -
lossless conversion to alternate containers
By krohm in forum Video ConversionReplies: 33Last Post: 12th Jun 2009, 03:19 -
jpeg to PDF is OK! But PDF to jpeg?
By bryankendall in forum ComputerReplies: 2Last Post: 14th Sep 2008, 15:53 -
JPEG lossless negatives ???
By piano632 in forum ComputerReplies: 4Last Post: 13th Sep 2007, 16:43
